Wireless on Rune
Re: Wireless on Rune
Postby PierreG64 » 11 Jun 2015, 21:08
Hello! Sorry for my english.
I post to say many thanks for the coders of runeaudio and for the forumers who says how to configure wifi with runeaudio.
I have runeaudio 0.3, a raspi 2 with digi + of wifiberry connect to a teac ud-501 in french "Que du bonheur" (but happiness in english? )
I have no formation in programming and with just this code:
Command :
- wifi-menu
i have configure my wifi with an Edimax wireless nano USB adapter.
You have made me a happy man!
Thanks! Because before, all i have try don't working or was to difficult to understand for me.
PierreG64
Postby hondagx35 » 11 Jun 2015, 21:13
Hi PierreG64,
welcome to the forum.
With RP2 and Rune Audio wifi configuration should be much easier.
No need to use wifi-menu or other tools.
See .
Postby PierreG64 » 11 Jun 2015, 23:59
Thanks Franck,
Yes it's really simple now. For people like me :D
I'm very happy with runeaudio.
PierreG64
Postby afick » 17 Jul 2015, 23:15
repo2
repo
afick
Postby wakeskate » 18 Jul 2015, 21:35
I had to mess with this for a while to get wireless to work
after a reboot.
Goto /etc/netctl/ directory
Under that dir their is another dir called examples.
Look at the descriptions to determine which one you need.
For example if you want to setup a wireless network with wpa and static ip.
open the file named wireless-wpa-static
This iswhat you will see
Description='A simple WPA encrypted wireless connection using a static IP'
Interface=wlan0
Connection=wireless
Security=wpa
ESSID='MyNetwork'
Key='WirelessKey'
IP=static
Address='192.168.1.23/24'
Gateway='192.168.1.1'
DNS=('192.168.1.1')
# Uncomment this if your ssid is hidden
#Hidden=yes
So you don't overwrite the example copy the one you need
but rename it to wlan0.
cp wireless-wpa-static /etc/netctl/wlan0
This will copy that config file to the netctl dir and then you can edit it.
nano wlan0
edit this file to meet what you need.
Make sure to leave the ' ' around options and you must leave
the /24 on the end of the static ip address.
You can also add
Netmask='255.255.255.0'
after the Gateway entry
Don't change anything until you get to the ESSID entry
in this field type the name of the Wireless Network you want to
connect to again make sure to include the ' ' in the entry
example:
ESSID='mynetwork'
Key='WirelessKey'
is you WPA password
If you don't know your DNS server.
You can use OpenDNS.
DNS='208.67.222.222'
DNS='208.67.220.220'
After you have this file saved in the /etc/netctl directory reboot you Pi
and give it about 20-30 seconds to find the network and connect.
Note: Not a secure way to handle this with the WPA password stored in the clear
but it will get you up and running with wireless even after a reboot.
Hope this helps someone.....
wakeskate
Postby afick » 20 Jul 2015, 17:20
I don't know how but it works :) it;s kind of mirracle :)
I tryied this solution few times but never worked. Now work for a firs time :)
Thank's a lot :). Now i'm waiting for 0.4 :)
afick
Postby Stert » 21 Jul 2015, 09:52
I'm having an issue with a 5ghz wireless N network.
I have wireless G and N networks running and want to use the N network for audio streaming. Problem is the AP does not appear in the settings page, only the G network.
I'm definitely using a wireless N adaptor, is there anything that I should try?
Stert
Postby azndoodle » 10 May 2016, 05:31
Has the wifi GUI been implemented in 0.4beta yet?
azndoodle
Postby hondagx35 » 10 May 2016, 12:06
Users browsing this forum: No registered users and 117 guests
