0.3 beta Pi2 Wireless Connection Issue (solved)
Postby Damagio » 07 Jun 2015, 02:20
Hi Guys,
Really loving RuneAudio, but having a tough time getting wireless connectivity.
Biggest problem is I cannot get my keyboard to type the { symbol
I am trying to add
network={
ssid="Network"
psk="s2df-4edd-0wtf"
to my wpa_supplicant.conf file
I cannot for the life of me find and open the locales or keyboard configuration file once I log in to root rune
any ideas?
Thanks!
Damagio
Re: 0.3 beta Pi2 Wireless Connection Issue
Postby hondagx35 » 07 Jun 2015, 10:13
Hi Damagio,
why do you want to edit wpa_supplicant.conf ?
The image uses netctl-auto and doesn't use wpa_supplicant.
With RP2 it is very easy to get wifi running via user interface.
Get access via wired network and then make your wifi settings.
Setting the locale on Arch Linux is described .
Postby Damagio » 07 Jun 2015, 17:26
Frank,
Thank you. I did not realize this as I am very new to Linux. I am reading through it, and it's over my head right now, so I will try again.
At least I am pointed in the right direction now. :-)
Mike
Damagio
Postby hondagx35 » 07 Jun 2015, 18:02
Hi Damagio,
- connect your RP2 via wire to your network, DHCP is enabled by default.
- go to the network page
- select your wifi card (wlan0)
- wait until the nearby APs are scanned
- select your AP from the list and enter your password (PSK)
Postby Damagio » 07 Jun 2015, 20:47
Frank...
I can't thank you enough! I made that WAY harder than it had to be LOL.
So nice to have it working without the extra cord. :-) I have it hooked up to a Schitt DAC and a little Toshiba HDD and it works and sounds amazing!
So kind of you to take the time out....thanks again!
Mike/Damagio
Damagio
