[Solved] I belive i am doing it wrong smb share
Postby TheKingOfChaos » 16 Feb 2015, 23:12
i have a share on a Windows 2012 r2 server and i have set runeaudio to Mount the share but it is not working
i have mountet the share manuel to /mnt/test and that is working ho can i check runeaudio smb Mount
i am running the latest build
hope any one can help me
Kenneth
TheKingOfChaos
Re: I belive i am doing it wrong smb share
Postby hondagx35 » 17 Feb 2015, 00:47
Hi TheKingOfChaos,
to help you we need more information.
Please post your manual mount command.
Are there spaces in your remote directory name?
If the mount operation fails, you should get some info from the UI.
Postby TheKingOfChaos » 17 Feb 2015, 20:56
I have mount the share and i am not getting any errors
Mount
Billed 1.PNG (52.87 KiB) Viewed 1364 times
Billed 4.PNG (5.78 KiB) Viewed 1364 times
as you can se in this picture i can browse the filshare by ssh
but files is not shoing up in runeAudio is there a way to debug the database update
Billed 3.PNG (56.4 KiB) Viewed 1364 times
TheKingOfChaos
Postby hondagx35 » 17 Feb 2015, 22:08
Postby TheKingOfChaos » 21 Feb 2015, 10:08
i found the problem i disable the ffmpeg and now it is working
thanks for the help
TheKingOfChaos
