Selecting SD card as library source
Postby rjs » 07 Dec 2019, 05:22
I am not seeing how to have the system search the SD card for audio files. In some of the forum posts, it appears that this option might have been turned off earlier this year. On the source page of the Rune UI I am only seeing options for network attached storage or USB drives.
With the price drop on SD cards, you can get a 256GB one for much less than the equivalent USB flash drive.
rjs
Re: Selecting SD card as library source
Postby electroremy » 21 Apr 2020, 10:50
It's possible to use SD card as library source, but it's not easy
I explain how to do here : how-to-put-mp3-files-on-sd-card-but-how-to-update-os-t7035.html
Also, the problem is you have to copy all MP3 files again after a SD Card Rune Audio update... I hope to find a solution about this.
Best regards
electroremy
