Rune support for Digi+pro
Re: Rune support for Digi+pro
Postby jmarcus » 14 Jan 2017, 18:34
I believe I have everything configured as suggested but my Digi+ Pro is not playing music [EDIT: I do not get a digital lock from the Digi+ Pro to my Schiit Bifrost 4490 DAC on Coax] (flashing red LED on RPi3 Board). Any suggestions on what I am missing would be appreciated. Please let me know if you need any other info. Thanks!
Info:
1) Digi + Pro works fine in Moode Audio
2) Using RPi3
3) Runeaudio version - release version: 0.4 (build: beta-20160313)
4) Linux version 4.4.36-1-ARCH (builduser@leming) (gcc version 6.2.1 20160830 (GCC) ) #1 SMP Fri Dec 2 19:23:34 MST 2016
5) Output from aplay -l:
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HiFiBerry Digi+ Pro HiFi wm8804-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
6) boot/config.text section:
#dtparam=i2c_arm=on
#dtparam=i2c_vc=on
#dtparam=i2s=on
#dtparam=spi=on
#dtparam=act_led_trigger=mmc
#dtparam=audio=on
#dtparam=uart1=off
#dtoverlay=pi3-disable-bt-overlay
# Uncomment one of these lines to enable an audio interface
#dtoverlay=hifiberry-dac
#dtoverlay=hifiberry-dacplus
#dtoverlay=hifiberry-digi
#dtoverlay=hifiberry-amp
#dtoverlay=iqaudio-dac
#dtoverlay=iqaudio-dacplus
7) Screenshot (attached) of MPD Configuration > Audio Output page in UI
debug.txt.zip
(16.08 KiB) Downloaded 524 times
Screen Shot 2017-01-14 at 12.30.57 PM.png (31.64 KiB) Viewed 2650 times
jmarcus
Postby hondagx35 » 14 Jan 2017, 23:16
Postby jmarcus » 17 Jan 2017, 00:04
Thanks for the prompt reply Frank. Actually the way I had it configured was correct. My issue was a weird HDD problem. It appeared to finish a Library Update and I could browse the drive but no streaming. After un-attaching and re-attaching the HDD after power recycle everything worked. Go figure!
jmarcus
Postby foxwelljsly » 22 Mar 2019, 11:54
Hi all,
Just popped a brand new rune build into my 2b/digi+ pro box. The build works fine through the on board audio and a Dragonfly USB DAC, but the through the digi+ pro, nada. Same on a 3.
Has this not been fixed yet?
cheers
foxwelljsly
Postby janui » 22 Mar 2019, 16:00
Postby foxwelljsly » 22 Mar 2019, 17:23
Before we get into uploading and analysing debug text, let's make sure I have the right build.
Build is RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB which was the most recent build on this page: http://www.runeaudio.com/download/#raspberry-pi-3
I have a 2B 1.1, a 3B 1.2 and the Digi pro.
Ideally, I'd like to use the 3b and the digi+ pro and once the library's built, make a copy for use in the 2b.
Which build should I be using?
cheers
foxwelljsly
Postby janui » 23 Mar 2019, 10:56
Hi foxwelljsly,
Try this build: runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532.html#p25819
We have now had more than 5,000 downloads and no reported problems relating to any of the HiFiBerry products.
