JustBoom Zero DAC not detected
Postby josepz » 15 Jan 2017, 19:25
josepz
Re: JustBoom Zero DAC not detected
Postby Yatsushiro » 15 Jan 2017, 19:49
You don't need 'device_tree_overlay=JustBoom-dac'
The overlay file is called 'justboom-dac.dtbo' so you should edit your config.txt to read 'dtoverlay=justboom-dac'
Yatsushiro
Postby josepz » 15 Jan 2017, 21:30
josepz
Postby Yatsushiro » 15 Jan 2017, 21:42
I assume you have updated the kernel? Does justboom-dac.dtbo exist in /boot/overlays?
If so, have you selected the justboom-dac under mpd configuration via the UI?
Yatsushiro
Postby josepz » 15 Jan 2017, 23:13
No, I just installed the last image file available for download... the justboom-dac.dtbo isn´t at the directory ... ok, I will search how to update, apt-get don´t wotk for arch, right?
Thanks for your help
josepz
Postby hondagx35 » 16 Jan 2017, 00:15
Postby josepz » 16 Jan 2017, 00:38
josepz
Postby josepz » 16 Jan 2017, 01:02
YES.....IT WORKS!!!. I did the update following this steps, and after the update the card finally was detected, :D Is detected as card1. Thank you very much for your support
josepz
Postby JustBoom » 16 Jan 2017, 13:37
Hi all,
Just to chime in here, the kernel in the current image of Rune Audio is quite an old one so does not have the correct drivers in it yet. Hopefully that may be fixed soon with any luck.
So one option is updating the kernel like you have done to pull in the new drivers.
Alternatively, and please note this has not been tested, but if there are other DACs out there using the same chip the JustBoom boards may work with their drivers. This is worth testing before going to the trouble of downloading a new kernel, however this is unsupported by us...
EDIT: the previous content of this post was actually incorrect. So I have deleted a lot of it to avoid any confusion.
If there is anything the Rune Audio devs need to get support built in (I believe we already sent all the boards over for them to play with) happy to help in any way that we can!
JustBoom - Affordable High Quality Audio for Everyone!
https://www.JustBoom.co
JustBoom
Postby DomieMic65 » 23 Feb 2017, 20:40
DomieMic65
Users browsing this forum: Bing [Bot] and 40 guests
