FM radio
FM radio
Postby bo.vestergaard » 04 Oct 2016, 08:53
Has anyone successfully configured Runeaudio to play FM radio. In that case, what hardware did you use?
bo.vestergaard
Re: FM radio
Postby Discovery » 05 Oct 2016, 10:05
Hi Bo,
Have you explored the Webradios section of the library yet? Strictly speaking, FM radio as such is not available but many radio stations provide a stream of their output which you can find and receive.
True FM requires an FM tuner. This outputs an analogue signal so is of no use to a Pi. On my second system, I have an Audiolab 8000T tuner (superlative sound) and I feed the output directly to a power amp via a passive pre-amp. The other input on the pre-amp is a DAC.
Streaming radio is usually of acceptable quality for most purposes and requires no more equipment or outlay than you will already have in place for your Pi. I personally connect my Pi with ethernet rather than wifi and have had no gaps, glitches or clicks since doing so. If you don't have ethernet near your Pi, invest in a pair of power line LAN plugs - this works fine for me.
Let us know how you get on.
Trevor
Discovery
Re: FM radio
Postby KHatfull » 05 Oct 2016, 14:59
Synology DS214+ -> RP3 -> Hifiberry Digi+ -> Audio-Gd NOS1704 (coax) -> Audio-GD C-2 preamp/headphone amp ->
1) Yamaha M-4 Power Amp -> Energy Pro 22 Speakers OR 2) HiFiMan HE-400i
Audio Nirvana!!!
KHatfull
Re: FM radio
Postby pelliott321 » 05 Oct 2016, 15:14
ok you peaked my interest into Absolute Radio from the UK
I went to their website and they claim the streams are only available within the UK because of advertising agreements
You eluded to a way around this. Any hint on how?
pelliott321
Re: FM radio
Postby Yatsushiro » 05 Oct 2016, 18:57
This, , may be of use...
Yatsushiro
Re: FM radio
Postby pelliott321 » 05 Oct 2016, 20:41
Not for me.....all Absolute Radio are page not found
thanks anyway
pelliott321
Re: FM radio
Postby Yatsushiro » 06 Oct 2016, 08:44
Yatsushiro
Re: FM radio
Postby KHatfull » 06 Oct 2016, 17:01
Audio Nirvana!!!
KHatfull
Re: FM radio
Postby KHatfull » 06 Oct 2016, 17:17
Audio Nirvana!!!
KHatfull
Re: FM radio
Postby bo.vestergaard » 07 Oct 2016, 11:30
Thank you for your replies but I am specifically looking for FM radio. I live in Madrid, Spain and I want to listen to some local FM stations. I am particularly interested in using a USB FM receiver. They sell them on ebay for a couple of Euros. I have an external area so I get a good signal. At the moment I have a traditional transistor radio plugged into my amp but it would be so much better to run it through the RP and DAC as the sound quality is much better.
bo.vestergaard
