HTTP Request to power down Raspberry PI
Postby ctownj30 » 05 Aug 2016, 13:10
Is there an HTTP request I can make that will turn of the RPi using the "Power Down" feature in the Rune UI?
I want to trigger a power down using my home automation system (which will wait a minute, then remove power from the PI). My automation system can make HTTP requests so this seems like an easy way to do it.
Dug around the UI HTML but could not find it.
(before anyone says "why would you want to shut the PI down": the system is in a rarely used vacation home that is prone to power outages - I keep losing high quality SD cards and hoping this helps).
thanks - djm
ctownj30
Re: HTTP Request to power down Raspberry PI
Postby deenski » 06 Aug 2016, 16:30
deenski
Postby hondagx35 » 06 Aug 2016, 17:50
Postby PetitMalin » 30 Jun 2020, 14:07
PetitMalin
Postby hondagx35 » 30 Jun 2020, 22:24
an HTTP POST request cannot be sent by using just an URL. (Except for the special case that there are no form fields and that the server doesn't care about the Content-type header.)
What is your intention?
Postby PetitMalin » 01 Jul 2020, 08:52
Just to integrate it into my home automation.
Before I used on my Synology LMS as a server and PiCorePlayer for my 5 Raspeberrys.
Now on my Syno Audio Station and Rune Audio (Audio Station because GoogleMusic will disappear)
The concept:
For the ignition of a Rasp: A wireless switch (Zigbee protocol) sends a signal to the Jeedom server which, through a script, switches "On" a SonOff switch (modified in ESP8266)for power "On" which starts the Rasp Player. (This part works, autoplay activated in Rune Audio)
In Jeedom a virtual state to toggle "On" (To know if the Rasp in On or OFF in the script)
In Jeedom possibility to do Play, Stop, Next, Previous, Shuffle, Volume UP and Volume Down in virtual command
For the extinction the same button (wireless switch)
The script check if the Rasp is On or Off
And here i need to post a shutdown command (Hence my question)
A ping request verifies the extinction of the Rasp
Toggle the virtual state to "Off"
After that the script turns off SonOff to cut the power
Thank's for your interest, If you have any question...
Nop
PetitMalin
