AUDIOPHONICS RaspDIGI LTE HIFI Streamer Raspberry [RESOLVED]
Postby charles6680 » 16 Jun 2016, 13:35
Hi Friends,
I have just made a box similar to this link (photos to follow). I intended to use RuneAudio UI , but I have difficulties to configure the UI to read the GPIOs, the Digi+ and the Pwr Mgt Module. Can anyone so nice help?
I even have a problem with my keyboard (I use US keyboard, but the default UI keyboard layout is different), how to change to match?
Thank you in advance.
Charles
2016-06-16 20.41.59.jpg (231.04 KiB) Viewed 1975 times
charles6680
Re: AUDIOPHONICS RaspDIGI LTE HIFI Streamer Raspberry Pi 2 S
Postby charles6680 » 16 Jun 2016, 13:39
I have checked all wiring and is correct. This is the back view.
2016-06-16 20.42.44.jpg (232.52 KiB) Viewed 1971 times
charles6680
Postby hondagx35 » 16 Jun 2016, 14:06
Postby charles6680 » 16 Jun 2016, 15:02
The GPIO 4, 17 & 22.
The Pwr Mgt Module is ATX like. Which gives Softstart, Softshutdown & full power off.
See this link
I will study the link provided but it seems for the DAC+
THANKS.
Charles
charles6680
Postby charles6680 » 16 Jun 2016, 15:31
I tried to change the keyboard to us layout accordingly but does not work. Is it simply type keymap=us and exit and then reboot? Nothing changed!
Can you show me the scripts (step by step)? I am totally no knowledge of Linux language.
Thanks again.
Charles
charles6680
Postby charles6680 » 16 Jun 2016, 16:57
Hello Frank,
With big smile!
Finally, I have successfully changed the keyboard to US layout and activated the Digi+.
With Rune, it sounds excellent. Absolutely excellent!!
Remaining, is to make the Pwr Mgt Module working. I will continue by consulting your provided link for the DAC+.
Charles
charles6680
Postby charles6680 » 16 Jun 2016, 17:13
Present inside look. All wires connected.
2016-06-17 00.16.11.jpg (247.58 KiB) Viewed 1943 times
charles6680
Postby charles6680 » 17 Jun 2016, 17:28
I found the above discussion in Audiophonics' Forum.
Following it, my DIY Unit is now full functioning.
Frank, Thank you for your help start from the very beginning.
Charles
charles6680
