Pi3 and DAC+ Pro
Re: Pi3 and DAC+ Pro
Postby hondagx35 » 12 Apr 2016, 17:12
Postby tobvc » 12 Apr 2016, 19:38
now that is interesting. Thanks for your testing.
I set up a share on a Windows 10 PC and played the test file (Pi 3 + DAC+, over wifi) multiple times. Every time the channel swap problem occured, although sometimes it took some minutes of playback.
If you want to do further testing without being bothered by the sine tone, you could just play the file on repeat while the balance knob is turned all the way to the left. If a beep appeares, that is a channel swap. If not, last thing I could imagine is that my Pi is defective.
Tobi
tobvc
Postby tobvc » 13 Apr 2016, 12:28
Ok, today the Pi 2 B and an EW-7811UN wifi dongle arrived. Wifi works very stable out of the box (with both DACs).
With both the DAC+ and the DAC+ pro, Shairport works like a charm, no furious channel swapping anymore.
Playback of 16 bit audio content also does not suffer channel swapping. After ~15 min. of testing for both DACs each, not a single swap occured.
Tobi
tobvc
Postby hondagx35 » 06 May 2016, 21:35
the channel swapping (RP3) seems to be solved see .
Postby Snerg » 08 Jun 2016, 01:02
Hi guys,
I am another one with WiFi connection dropping while using RPI3 built in WiFi + Hifiberry DAC+Pro + Runeaudio.
- RPI3 WIFI ok tested many times - streaming with kodi,
- Hifiberry DAC+Pro with my RPI3 ok when running Moode connected through built in WiFi,
- Same setup but running Runeaudio no joy. Tried rune 0.3 and 0.4, all tweaks mentioned here and elsewhere, all kind of updates and still same result. No matter how powerful my PSU is btw.
I've noticed weird phenomena tho. When holding USB ports with my fingers (earthing RPI3) for 10-20s while running whole Runeaudio system it seems that WiFi is working fine or re-gaining connection... As soon as I let go connection is dropping again.
But no need for such thing with Moode. It looks like drivers for Hifiberry DAC+ (can't see one for DAC+PRO) that Runeaudio is using are disarming WiFi's module GND 'signal'. Wonder if anybody else noticed such behaviour.
Snerg
Postby ToKa » 14 Jun 2016, 09:20
ToKa
Postby Snerg » 26 Jun 2016, 19:33
Snerg
Postby hondagx35 » 26 Jun 2016, 21:03
Hi Snerg, hi ToKa,
did you update the kernel as described ?
Postby ToKa » 30 Jun 2016, 07:53
ToKa
Postby Snerg » 19 Jul 2016, 22:57
Snerg
Users browsing this forum: Bing [Bot] and 19 guests
