Change port 80
Change port 80
Postby anfuca » 08 Nov 2015, 12:28
Hi all,
I want to access by ddns to my Raspberry Pi with RuneAudio in it, but, due to my Internet provider configuration, the port 80 is busy and redirects me to another thing...
I have tested my Raspberry in other network, and just opening the port 80 to the Raspberry IP, it works like a charm.
So the question is, can I change the port 80, or the port 80 is the only can I use because of the http connection?
Thanks in advance!
anfuca
Re: Change port 80
Postby hondagx35 » 08 Nov 2015, 12:58
RuneAudio uses nginx as web server and the ports are configured in /etc/nginx/nginx.conf.
Re: Change port 80
Postby anfuca » 08 Nov 2015, 13:14
Thanks for your answer.
I've changed the port 80 to another in that file.
-Reboot.
-Now RuneAudio is running in the new port IP:Port to access to it.
-But it isn't working (take a look at the screenshot attached).
It seems that I should change the port in other place... but where?
Thanks!
Screenshot
Captura de pantalla 2015-11-08 a las 13.14.36.png (42.6 KiB) Viewed 2104 times
anfuca
Users browsing this forum: Bing [Bot] and 10 guests
