Problem with Wifi
Problem with Wifi
Postby cassius36 » 12 Oct 2015, 12:52
I am french, so I beg your pardon for my english.
Wifi does not run on my Raspberry pi2.
Is it necessary to plug a screen to look and modify the system for installing the dongle?
Thanks in advance.
Cassius
cassius36
Re: Problem with Wifi
Postby hondagx35 » 12 Oct 2015, 17:07
Postby cassius36 » 12 Oct 2015, 20:24
Thanks for your response.
I mean that it does not works.
I think i have installed the last version of RuneAudio.
I try to send you a picture of my dongle but it seems too big to be sent via this website.
Thanks a lot.
Cassius
cassius36
Postby cassius36 » 12 Oct 2015, 20:35
Precision : RuneAudio works fine with wired ethernet... But not with Wifi!
cassius36
Postby hondagx35 » 12 Oct 2015, 20:50
Postby cassius36 » 12 Oct 2015, 21:42
The screen is exactly the same.
When i write "Lsusb" i see : "Bus 001 Device 004: ID 148f :5370 Ralink Technology, Corp. RT5370 Wireless Adapter
What can I do now ?
cassius36
Postby cassius36 » 12 Oct 2015, 21:50
This is the Technical Data Sheet for my dongle
OVERVIEW
Wi-Pi Overview
Wi-Pi is a high performance, cost effective WLAN USB module which connects the Raspberry Pi low cost computer, to a Wi-Fi local area network. Wi-Pi uses the latest 802.11n Wireless Technology, and can support data rates of up to 150 Mbps, compared with older 54 Mbps 11g products. It also benefits from a higher wireless LAN bandwidth, making data transmission more efficient.
Wi-Pi also supports wireless roaming, ensuring a more consistent wireless connection to a wireless access point. Wi-Pi uses the latest international wireless CCA air channel detection technology, enhancing wireless performance.
Hardware Features and Performance
Physical Interface
USB 2.0
Antenna
Built-in smart antenna
Permissible Working and Storage Environments
Working Temperature: 0 °C to +40 °C
Storage Temperature: -40 °C to +70°C
Wireless Features and Performance
Standards
IEEE 802.11n; backward compatible with IEEE 802.11g and IEEE 802.11b
Transmission speed
11b: 1/2/5.5/11Mbps
11g: 6/9/12/18/24/36/48/54 Mbps
11n: up to 150 Mbps
cassius36
Postby hondagx35 » 12 Oct 2015, 22:25
Postby cassius36 » 13 Oct 2015, 21:00
My problem is resolved.
I apologize because I had not read carefully enough the configuration guide for parametrage wifi ! The dongle WiPi works fine immediatly.
...But... I have another problem : I can't use Spotify. I don't know how to join my account and listen music on line. Runeaudio ask me to add music in the queue! I do have music on a USB key and hard disk but I want also to listen music on the web.
Thanks in advance!
Cassius
cassius36
