My solution to pops and clicks
Re: My solution to pops and clicks
Postby tux » 26 Mar 2014, 21:14
tux
Postby FauDrei » 27 Mar 2014, 15:05
FauDrei
Postby tux » 27 Mar 2014, 15:43
just dmesg and see these numbers for your usb dac!
tux
Postby FauDrei » 27 Mar 2014, 19:26
FauDrei
Postby tux » 27 Mar 2014, 19:56
tux
Postby tux » 28 Mar 2014, 11:16
It' seems i have to study more on usb devices and linux :p
I believed that these numbers refer to the bus id. I found out that they change with different devices (athough it's not a device id as i understand).
I had the opportunity to retest the friends' dacmagic and with the correct id, the FIQ reported NYET errors disappeared.
So until now the issue has been fixed in 2 dacs i have tested and i believe that this tweak will have an positive effect for many of you.
tux
Postby vortex » 28 Jun 2014, 15:13
I've applied the solution in the first post but unfortunately it made things worse. While I used to have loud clicks that are intermittent and come far in between, now I have softer but continuous clicks.
My external DAC is AudioEngine D1. I guess I will have to wait for 0.3 alpha and hope that the clicks and pops do get eliminated eventually.
vortex
Postby cmh714 » 15 Aug 2014, 02:59
this appears to be baked into v0.3 now
just edit /boot/cmdline_rune.txt
currently line 4 is enabled but line 5 has the setting from this post. Change and reboot. Should be good to go....
