Need power supply advice from 12 volts
Postby Bruce » 25 Jun 2015, 00:04
I am testing a Pi 2 with a WiFi dongle and a UCA202 DAC in my boat. I have tried two USB power sources in the boat. One is a Chinese USB power supply, the other is a Blue Seas USB outlet. Using either I had a high pitched tone and could hear noises from the Pi through the speakers. I do not have any noise if I use my MacBook to power the Pi. The DAC and WiFi are powered by the Pi.
So I believe I need a cleaner 5 volt power supply from the boats 12 volts. I am considering using a UBEC.
What do you recommend?
Bruce
Re: Need power supply advice from 12 volts
Postby chuckles » 28 Jun 2015, 23:12
This device might help. It stops the whining in my car.
Noise Supressor.JPG (198.06 KiB) Viewed 1254 times
chuckles
Users browsing this forum: No registered users and 69 guests
