Hardware volume control not working
Postby deef » 02 Jun 2015, 00:52
I'm trying out Rune for the first time and I can't get the hardware volume to work, I used both Moode and Volumio in the past, and both had working hardware volume control, with the same setup. I'm using a cheap usb-stick soundcard.
The volume knob in the webui, seems to be controlled by the microphone in alsamixer as it is now.
Any ideas?
deef
Re: Hardware volume control not working
Postby rasti » 02 Jun 2015, 07:47
I know it doesn't really help you but I have the same problem with HifiBerry.
I simply switched back to software volume control....
Ralf
rasti
Postby Orion » 02 Jun 2015, 09:12
Hi Ralf and deef,
please post here your debug data, according to and we'll help you to solve the problem.
Before to copy the debug output to the clipboard, please reload the debug page at least two times.
Ciao.
Simone.
- Embedded Hi-Fi music player
Orion
Postby rasti » 02 Jun 2015, 10:16
Hi Simone,
here we go http://pastebin.com/wdx8zdzC
The error is that the volume button
always jumps back to 100 no matter volume I select.
Regards
Ralf
rasti
Postby hondagx35 » 02 Jun 2015, 10:30
Postby rasti » 02 Jun 2015, 10:57
rasti
Postby Orion » 02 Jun 2015, 11:04
Orion
Postby deef » 02 Jun 2015, 11:58
Here's the debug data: http://pastebin.com/9GPzUTe3
I'm no expert, but my guess is I need to change my usb card to default or something like that. I'm not sure exactly what to do.
deef
Postby hondagx35 » 02 Jun 2015, 12:37
Postby deef » 02 Jun 2015, 13:01
Worked like a charm, thank you.
deef
