Hardware Volume Control on Pi2 with Hifiberry DAC+
Postby leeshep » 08 May 2015, 23:36
I've got my Raspberry Pi2 with a Hifiberry DAC + all set up and working with Rune Audio Beta 0.3.
I had to uncomment a line in the config file in order to get the Hifiberry to work but I can't get the volume control to do anything.
I've tried the various SSH command suggestions in the sticky thread on this forum but it still won't work.
Can anybody help?
Thanks in advance,
Lee
leeshep
Re: Hardware Volume Control on Pi2 with Hifiberry DAC+
Postby mika-nl » 09 May 2015, 13:03
I think you have to edit config.txt.
[root@hifiberry ~]# cat /boot/config.txt |grep hifi
#device_tree_overlay=hifiberry-dac
device_tree_overlay=hifiberry-dacplus
#device_tree_overlay=hifiberry-digi
#device_tree_overlay=hifiberry-amp
after you edit the file you have to select the output in menu >MPD
ssh root@runeaudio
pass: rune
grtz mika
mika-nl
Postby leeshep » 09 May 2015, 18:00
I've already edited the config file and I have sound output through the DAC+. The problem I have is even though I have selected hardware volume control and applied the setting I can't adjust the volume. I have tried the fixes in the sticky thread above this but I can't get the volume control to do anything.
Lee
leeshep
