[SOLVED] Getting 404 Not Found nginx/1.4.7
Postby kovacsbv » 15 Feb 2015, 05:13
I installed the 0.3 Beta image on a Raspberry Pi and when I point a browser at the IP address, I get 404 Not Found nginx/1.4.7.
Do I need to change something?
Vic
kovacsbv
Re: Getting 404 Not Found nginx/1.4.7
Postby ACX » 15 Feb 2015, 16:05
Of course this is not the expected behavior, so something has gone wrong... please check your installation or consider to reinstall it from scratch.
Postby roscho » 25 Mar 2015, 11:02
I have a similar problem which has occurred since I upgraded from Linux Mint 16 to Linux Mint 17. Prior to that I was able to login to runeaudio.local using Firefox. Just wondering if I have too many devices on my network or is it an issue with Linux Mint 17?
roscho
Postby Anonymous Coward » 27 Mar 2015, 02:14
I got the same problem after doing a full upgrade using pacman. After some trial and error, the culprit seems to be the update to the "redis" package. To fix this, I had to revert to the "original" version of "/usr/lib/systemd/system/redis.service" and reboot. This appeared to eliminate the 404 error, but I have not done much testing or analysis to see if there are any repercussions.
The original version looks like this:
---8<---8<---8<---8<---8<---8<---8<---8<---8<---
[Unit]
Description=Advanced key-value store
After=network.target
[Service]
#Type=forking
User=redis
PIDFile=/run/redis/redis.pid
ExecStartPre=/bin/mkdir -p /var/lib/redis
ExecStart=/usr/bin/redis-server /etc/redis.conf
ExecStop=/usr/bin/redis-cli shutdown
Restart=always
RestartSec=1
StartLimitInterval=30
StartLimitBurst=20
[Install]
WantedBy=multi-user.target
Anonymous Coward
Postby dgbrt » 29 Mar 2015, 14:21
Thanks so much... same happened to me, and I didn't have a clue where to look. You saved my day! - Your fix resolved my issue as well, so far no side-effects.
dgbrt
Postby ACX » 29 Mar 2015, 18:42
So the issue was caused by the pacman full update? (btw I wonder where you read to do that :))
Re: [SOLVED] Getting 404 Not Found nginx/1.4.7
Postby dgbrt » 31 Mar 2015, 21:17
Yes, exactly (pacman -Syu, to be precise). And where did I read I was supposed to do that? No idea, can't remember. That it would break the whole system was unexpected, though... :?
dgbrt
Postby SomeGuy » 18 Apr 2015, 19:23
After a host of issues I finally managed to get my Pi/Runeaudio combo up and running however, 5 minutes ago I am now getting the 404 error when attempting to connect to runeaudio.local.
Why has this happened? I have reinstalled this program 4 times already this week because things keep going wrong & I don't think I can face reinstalling again.
Can someone provide an idiot's guide to fixing this per chance? I can't even SSH into the Pi as none of the passwords work.....
SomeGuy
Postby SomeGuy » 18 Apr 2015, 21:54
Ok, so I appear to have resolved this issue.
SomeGuy
Postby eratical » 12 May 2015, 01:38
Thx a lot
Resolved the 404 issue after update
eratical
