Permanent web UI "spinner"
Postby markvr » 04 Feb 2015, 00:24
markvr
Re: Permanent web UI "spinner"
Postby skrodahl » 04 Feb 2015, 00:53
Hi markvr,
Did you also perform the update of RuneAudio that was described in the post that you linked to? If so, would be a good idea.
-skrodahl
skrodahl
Moderator
Postby markvr » 04 Feb 2015, 01:14
I updated from the command line and rebooted after my original post and it seems to have cleared the "spinner" for now, I'll see if it reoocurs!
Unfortunately I can't generate the debug logs using that method when this occurs, because the UI isn't usable. Is there a way to generate the logs from the cmd line?
markvr
Postby skrodahl » 04 Feb 2015, 07:21
There isn't any way of generating the debug information from the command line. This information doesn't change very much, you can do it before the UI crashes.
Anyway, there has been a lot of changes in the code. If you hadn't updated before, it will most certainly have fixed your problems now.
-skrodahl
skrodahl
Moderator
