USB is recognized but no music is found?
Postby bktruss » 16 Feb 2014, 02:11
I have v0.2-beta up and running on my Raspbeery pi B, have done the MPD database update and it successfully found my USB. I have each individual music artist in a separate folder on the root of the USB drive. My Raspberry Pi power source is from a wall plug, but the USB external drive is USB powered just so you know. Doubting a power source issue would cause this but just putting it out there. So, the problem is RuneAudio can see the USB but can't see any music, does all the music as in the actually mp3's have to be out of the folders onto the root of the drive for RuneAudio to see them? Any help would be appreciated, Thanks
EDIT:
I have added some MP3's to the root of a USB drive and it see them and plays them. So can RuneAudio see MP3's located in folders? I was also thinking the USB I attached originally had 400GB of music, maybe it was just taking a while to rebuild the database, was I impatient?
“One good thing about music, when it hits you, you feel no pain.” ― Bob Marley
bktruss
Re: USB is recognized but no music is found?
Postby chromisdesigns » 16 Feb 2014, 03:33
I had this same problem with both Logitech Media Server and Volumio on a Cubox. I believe it's a Linux file system permissions issue. How did you create the file structure on the external drive? For some reason, the "user"running the processes on the Linux device does not have correct permissions to access the file structure. Am waiting for the Cubox release of Volumio to see if this carries over.
Like you, I could see stuff at root, but not anywhere else, either on USB drive or memory stick .
chromisdesigns
Postby bktruss » 19 Feb 2014, 15:05
So I'm guessing this is an issue not worth addressing as this must not be a feature at this time or there is no fix.
bktruss
Postby chromisdesigns » 19 Feb 2014, 17:24
chromisdesigns
