Question about digital out of an usb soundcard (SB X-fi HD)
Postby d-roby » 09 Dec 2014, 15:54
Hello.. first of all.. many thanks for this nice project...I like Rune audio very much..you did a really good job! ;) :)
I just bougth a Raspberry Pi B+, and Rune Audio wors fine...very very nice interface
I connected a Behringer UCA 222 usb..it worked "out of the box" and i can get digital out from the soundcard
I also have a Soundblaster X-Fi HD USB, and i wanted to send optical SPDIF to my external DAC
But Audio output is only analog..
Is there a way to use spdif output of the Sounblaster (it is 24/96) instead of analog outputs?
Many thanks
Roberto
d-roby
Re: Question about digital out of an usb sondcard (SB X-fi
Postby ACX » 10 Dec 2014, 00:50
Hi Roberto,
take a look at this similiar issue:
https://www.libreoffice.org/bugzilla/sh ... i?id=74324
In our setup (using ALSA instead of PulseAudio) you should manually set the right subinterface in the /etc/mpd.conf file (I guess hw:1,1 instead of hw:1,0) and see if ot works.
The problem is that, at the time, the modifications yo do at the file won't stick after a reboot. A fix to this misbehaviour will come soon.
Postby AndreR » 10 Dec 2014, 12:05
Hi Roberto,
can you please send details on your configuration with the SX-fi HD connected to the Raspberry?
In order to post the debug info, please use PasteBin, following the instruction provided in the opening post of this thread:
runeaudio-0-3-beta-for-raspberry-pi-t502.html
Thanks.
AndreR
Moderator
Postby d-roby » 10 Dec 2014, 12:32
Hello... thank you very much for your replies..
i am a totally newbie in linux , sorry,,,
i just figured out how to edit mpd.conf :oops:
anyway, i will post a reply (and the requested debug info) later in the afternoon..
thanks again
d-roby
Re: Question about digital out of an usb soundcard (SB X-fi
Postby d-roby » 10 Dec 2014, 16:54
Hello... i modified the config in mpd.conf (hw:1.1) but nothing changed
this is the debug info
http://pastebin.com/vkeAuFTY
many thanks
d-roby
Postby AndreR » 10 Dec 2014, 18:03
Thanks Roberto.
The folks at RuneAudio are working on refining the way subdevices are handled - in order to try to support your Creative device the info you posted are a good starting point.
I will send you a PM in order to gather more info - should they be needed.
Stay tuned...
AndreR
Moderator
Postby d-roby » 10 Dec 2014, 18:15
That's fine!
Thank you very much for your effort, very appreciated
d-roby
Users browsing this forum: Bing [Bot] and 1 guest
