[Solved] Ghost NAS mount
Postby ICLlP » 06 Dec 2014, 12:26
According to the sources UI I have three NAS mounts, but in reality I only have two. The third is a ghost. Does anyone know how can rid of this?
ICLlP
Re: Ghost NAS mount
Postby ACX » 06 Dec 2014, 18:14
It could be that that resource hasn't been unmounted properly.
Browse in /mnt/MPD/NAS/ and delete the "ghost" folder.
Re: Ghost NAS mount
Postby ICLlP » 06 Dec 2014, 19:48
How do I do that?
ICLlP
Re: Ghost NAS mount
Postby ACX » 06 Dec 2014, 22:20
If you are not confident with the command line, use a FTP/SFTP client (e.g. FileZilla), connect to your Rpi with in SFTP and do it there.
Re: Ghost NAS mount
Postby ICLlP » 06 Dec 2014, 22:31
I'm quite happy ssh ing in through Terminal on the Mac. It's once I'm there I need instructions for dummies.
ICLlP
Re: Ghost NAS mount
Postby cmh714 » 07 Dec 2014, 00:50
rmdir --ignore-on-non-empty /mnt/NAS/blah
where blah is your folder.
if that doesnt work, rm the files first then rmdir the folder....I was having issue with the --ignore-on-non-empty parameter
Re: Ghost NAS mount
Postby cmh714 » 07 Dec 2014, 01:08
my bad the parameter is --ignore-fail-on-non-empty
Re: Ghost NAS mount
Postby ICLlP » 07 Dec 2014, 10:32
Is this what you mean?
rmdir --ignore-fail-on-non-empty /mnt/NAS/2
2 is the name I gave to what has now become a ghost.
I just tried it and this is what happened:
[root@runeaudio ~]# rmdir --ignore-fail-on-non-empty /mnt/NAS/2
rmdir: failed to remove '/mnt/NAS/2': No such file or directory
ICLlP
Re: Ghost NAS mount
Postby Beelzebassie » 07 Dec 2014, 12:49
Probably not related to your problem, but I also did encounter a 'ghost' mounted folder.
Problem was the name I gave it in RA started with an underscore, '_'. Removed the underscore, and now RA sees it properly.
Beelzebassie
Re: Ghost NAS mount
Postby cmh714 » 07 Dec 2014, 17:01
If the rmdir command couldnt find your directory/folder, then it sounds like it doesnt exist which means the ghost drive is most likely coming from the database.
You can try and add a new NAS mount and see if the ghost disappears.....thats what happened to me with Webradio's...cant hurt to try.
Users browsing this forum: No registered users and 73 guests
