Rpi B+ v0.3 + AudioQuest DragonFly V1.2 = No sound
Re: Rpi B+ v0.3 + AudioQuest DragonFly V1.2 = No sound
Postby thanhvo31 » 16 Nov 2014, 03:07
thanhvo31
Postby thanhvo31 » 16 Nov 2014, 03:11
thanhvo31
Postby cmh714 » 16 Nov 2014, 05:15
Sure, I will flash you a clean Rune from the image, get it updated with git pull and pacman, and get the DragonFly working with just the eth0 interface. I'll back it up, zip it and post it.....stay tuned for a link, I will try and do this now but it may not post till tomorrow.
Postby cmh714 » 16 Nov 2014, 06:45
file is being uploaded now Thanh, probably post the link for you tomorrow since its getting a little late here.
My good deed for the day....I will guess you may be Buddhist. I have the Bodhisattva Quan Am on a chain around my neck :)
Postby thanhvo31 » 16 Nov 2014, 12:51
thanhvo31
Postby cmh714 » 16 Nov 2014, 16:35
Nope not Vietnamese, but I assumed you were :) I am just into Buddhism a bit.
Heres the link for you: https://www.dropbox.com/s/wihwr3zjbw9bo ... mg.gz?dl=0
Its Gzip'ed, so unzip it, and flash and you should be good to go. Like I said its a 1.0 DragonFly but I have used my images before for my buddy who has a 1.2 so it should work fine.
I tested streaming radio and it was good. The only thing I had to do to make it work was adjust alsamixer to get sound as it was set to 0db for the DragonFly.
GL
Postby thanhvo31 » 17 Nov 2014, 07:24
thanhvo31
Postby thanhvo31 » 18 Nov 2014, 01:18
Finally I had tested but still no sound, obviously after playing with alsamixer.
thanhvo31
Postby thanhvo31 » 19 Nov 2014, 14:53
I just found a topic about USB Audio.
And I had already run to step 6 to speaker-tested successful to AQ DF1.2 but no further progress on step 7.
thanhvo31
Postby cmh714 » 19 Nov 2014, 15:51
I am out on the road Thanh and dont have my Pi or my images with me. Thats a clean image and was playing music fine when I zipped it up for you. I already tweaked alsamixer so the sound would work, so thats very interesting that you are still having trouble. I mean the only difference is the DAC as mine is the 1.0 and yours the 1.2
I will ask my buddy to bring over his 1.2 when I get back home at the end of the week to see if there is any difference. I will use the image I sent you and let you know what/if anything that I find.
Is it possible that you have a defective Pi or something like that? anyway to test in another Pi?
Users browsing this forum: Bing [Bot] and 2 guests
