Switch from volumio to rune audio ?
Postby arginine » 28 Apr 2014, 23:28
I'am a satisfied user of Volumio. I connect on my raspberry pi a 20x4 LCD, a temperature probe and a IR sensor. Everything is working well, my music (ALAC, i.e apple lossless files) are stored on a NAS. I'am using a i2s DAC (ESS 9023) through an USB to i2s converter (from diyinhk).
I would like to make a try of your rune audio hifi distribution, and possibly switch, if the sound is better. But, before I would like to be sure of the following :
- Is there any one who did actually compare the sound quality of Volumio Vs RuneAudio ?
- Can i read my music files (stored on a NAS) via NFS share ?
- Does rune audio handle output ALAC files ?
- Does the album covers are handled correctly ? (using Mpod or MPAD) ?
- Does my usb-i2s and DAC will be recognized by Rune Audio ?
- For the LCD, temperature probe, IR sensor …. is there "library" for RiscOs for driving all of that ? (I mean can I use apt-get update, install act ect)
- Can I installed python ?
Sorry for all of this questions
F
arginine
Re: Switch from volumio to rune audio ?
Postby emma » 29 Apr 2014, 20:11
I'm currently running both. I can't get my lcd working with archlinux so one box is on volumio, one with Rune.
The Rune UI is more polished and going to become even more so with beta 3. I have a hifiberry on the Rune and a cheapo USB board, soon to be a hifiberry, on the volumio box so can't comment on sound as the hifiberry is WAY better than the usb board.
Let me answer the others where I can
Yes
No idea.
Yes, natively.
With a bit of fiddling, yes. In the imminent V3, yes.
It's on archlinux and you need to use pacman instead of apt-get.
Yes.
emma
Postby ACX » 29 Apr 2014, 23:07
Hi arginine,
I'm sure that you already know that using RuneAudio is as easy as writing an image to a SD card, so I suppose you don't have any SD left laying around your home... or you are too lazy to try it :D
Anyway, here there are the informations you requested, in order to be useful to others with the same questions.
Please mind that, in the following points, I'm always referring to the last (coming soon) 0.3-release, that can be considered as a milestone and represents a leap from the past (and from RaspyFi/Volumio), as disclosed .
1) I can't say if RuneAudio sound quality will be better or worse to you. The only way to discover it is trying by yourself.
What I can say is that Volumio's sound quality comes from a work of research and optimization made by during our collaboration in the RaspyFi project. He created the so called "kernel profiles", letting users tweak some low-level system parameters to adapt the "sound signature" to the personal taste. Those optimizations are still in development under RuneAudio project, and are reviewed every time the distro is upgraded and a different kernel version is used.
2) Of course you can play music from network mounts, using both SMB/CIFS and NFS protocols. Moreover, the "Add network mount" wizard has been improved since the previous 0.2-beta.
3) Yes, you can play ALAC files, but you have to enable "FFmpeg decoder plugin" first, under MENU > MPD. It is disabled by default due to possible performance issues.
4) Album covers are natively displayed in the main playback screen of RuneUI
5) I2S DACs support is seamlessly integrated in RuneOS/RuneUI and easy to manage. Currently supported DACs are: G2Labs BerryNOS, G2Labs BerryNOS mini, HiFiBerry DAC, HiFiBerry Digi, IQaudIO Pi-DAC, RaspI2SPlay3
6) You can easily install and update packages via pacman, the default packet manager in Arch Linux
I hope to have satisfied your curiosity :)
Postby arginine » 29 Apr 2014, 23:10
Hello Emma,
Thanks for your reply, very helpful.
Considering that the LCD stuff is going to be very hard to setup (for me) and the fact I'm happy with volumio (recently updated), I think I'll stay with my current setup.
F
arginine
Postby wick » 15 Aug 2014, 00:26
wick
Postby ACX » 06 Nov 2014, 01:54
I bump this old thread because everyone who has not tried the recent 0.3-beta release yet should absolutely do it :) It's a huge leap forward compared to the previous 0.2-beta version we were talking about here.
Postby KHatfull » 06 Nov 2014, 06:45
Since I can't play 24/192 FLAC files on Volumio with my Pi-DAC+ I guess RuneAudio sounds better.
I can tell you the UI here is faster and more polished. Everything works as I'd expect, even in a beta release. Heck with Volumio...
Synology DS214+ -> RP3 -> Hifiberry Digi+ -> Audio-Gd NOS1704 (coax) -> Audio-GD C-2 preamp/headphone amp ->
1) Yamaha M-4 Power Amp -> Energy Pro 22 Speakers OR 2) HiFiMan HE-400i
Audio Nirvana!!!
KHatfull
Postby ACX » 06 Nov 2014, 11:43
Postby asturnauta » 08 Nov 2014, 11:54
I have used runeaudio and volumio and in my configuration runeaudio boots up faster than volumio.
asturnauta
