I need some advice step by step how to connect my NAS direct to Pi3b via ethernet cable and to mount an folder / subfolders form NAS.
I want to try this DIRECT connection because my home network is very crowded, also the router handle more then 50 connections permanent wifi / cable, and when I try to listen Hi Rez audio DSD files 128/256 on my DAC, I have a lot pops and clicks, also because the NAS is connected far away ( more then 50 meters with CAT 5e old cables , inside wall ) and I try to find how to listen those files without this extra noise and I temporary move the NAS in the same room with audio system and reduce length of cables, solve the problem
What I done already in NAS ( ASUSTOR 6604T )
- I already allocate on second LAN port in NAS, static address and same gateway with Pi
- Pi has already allocated a static IP address and gateway.
What I need to do ?
Please try to explain to a very newbie on LAN / LINUX / RUNE AUDIO .
The explanation should be very clear, what need to do on NAS, ( CISM or NFS or something ) settings and permissions and also what settings need to make on rune audio via UI interface or SSH ... or extra if is some.
Thank you in advance for support and advices
Best
Cristache
