web radio
web radio
Postby tsawyer » 20 Jan 2021, 02:31
I was playing with some of the option sources and was trying to connect to a web radio url. when I setup a connection for
https://www.internet-radio.com/servers/ ... d=1&t=.pls
it seems like the box is attempting to connect then nothing. I see 3 dots but nothing happens. if I put in the same url into vlc, connects fine. so my network config allows connections to web radio but I'm not getting it on the rune. I manually added the station and attempted to import the setting by going to /mnt/MPD/ and creating a file Webradio. so far neither allows the connection. is this the correct way to setup webradio?
tsawyer
Re: web radio
Postby cmh714 » 20 Jan 2021, 02:57
Save the pls to your desktop or wherever and then open it in an editor and there you will find the actual uri needed for Rune.....
Re: web radio
Postby tsawyer » 20 Jan 2021, 15:09
tsawyer
Re: web radio
Postby cmh714 » 20 Jan 2021, 17:27
yep, its not working for me either....in VLC codec says its a mpga......i dont have ffmpeg enabled it may need that???
GL
Re: web radio
Postby tsawyer » 20 Jan 2021, 20:50
looking at your post, I did try it exactly as written. if I copy that exact string, open vlc and say stream from that link, error. if I strip off everything and use ip address and port to say stream, it works. when I put in the entire string into firefox as posted, it gave me a file to download/open with (I have vlc associated with the file extension) things work. again, stripping off everything but the ip address and port, the page shows SHOUTcast Server v2.5.5.733/posix(linux x64) and this info (at time of connection)
Listing Status: Stream is currently up and public
Stream Status: Stream is up (MP3 @ 192 kbps, 44.1 kHz) with 125 of 200 listeners (123 unique)
Listener Peak: 202
Avg. Play Time: 9 hours 41 minutes 48 seconds
Stream Name: Metal Express Radio
Stream Genre(s): Heavy Metal
Stream Website: www.metalexpressradio.com
Playing Now: British Lion - Last Chance
I thought there was another post asking about shoutcast, I'll have to do into that another time. purely from a few things and not a lot of digging it, my best guess a problem understanding shoutcase sources since the other web radio defaults play as soon as the page is rendered by a browser.
tsawyer
