Raspberry model A - ok?
Postby readiescards » 03 Feb 2014, 08:46
Will RuneAudio work fine with a model A or does the model B give extra advantages/performance/hifi quality?
Paul
PS Thanks for putting this together
readiescards
Re: Raspberry model A - ok?
Postby ACX » 03 Feb 2014, 09:27
Hello readiescards, it should work without problems, but since model A doesn't have ethernet you have to connect it via Wi-Fi. Wi-Fi will be supported from 0.3-beta version; in the meanwhile you can try to configure it manually, following the instructions linked here:
wi-fi-integration-t76.html
