Control Rune Audio via TCP/IP commands
Postby electroremy » 21 Apr 2020, 11:28
My final goal is to integrate my Raspberry Pi / Hifiberry Dac / Rune Audio in a DIY Automation system 8-)
In each room of my house, I have an "Human Machine Interface" :
- an Arduino Uno
- a 2.8" tft touch screen SPI module
- a TCP/IP SPI module
An Arduino Mega is use a the central unit of my automation system.
Every Arduinos are connected together via TCP/IP Ethernet modules, with a router.
The "central unit" Arduino Mega can turn on or off several devices ; for my audio systems, it will :
- turn on or off laud speakers in each room, connected to a single audio amplifier
- select an FM aerial
- control the amplifier source, volume, FM station via IR remote control signal
- turn on or off the raspberry pi wich runs Rune Audio
So I want to connect the Raspberry Pi wich runs Rune Audio via Ethernet on my Automation system, in order to control Rune Audio via my Arduinos Uno Human Machine Interface.
Indeed, I want to know if it's possible to send TCP/IP "commands" to Rune Audio :
- play
- pause
- next track
- previous track
I want to program a full control remote via TCP/IP, that can browse my MP3 files :
- get genre directory list and change genre directory
- get artist directory list change artist directory
- get album directory list change album directory
- plays album (play, pause, next track, previous track)
I want to know if it's possible, or witch langage and IDE I had to use to program my own plugin for Rune Audio.
Indeed My Arduinos Uno Human Machine Interface will use the TFT touch screen to browse MP3 files
A long time ago (20 years) I made a "MP3 box" with an old computer running under Windows 95.
I've made a DIY Human Machine Interface with a LCD screen and keyboard push buttons, you can view photos here :
Also I made electronics for 27 years...
I created also software, for example you can find "CiDess", a free software to create PCB, it has english version and english website :
http://cidess.free.fr/index-gb.html
Now I want to deals with modern electronic : Raspberry Pi, Arduinos, TCP/IP...
By my time I have to deals with :
- 8051 and assembler language
- eproms
- no Internet
- slow and low memory but very fun computer like Amiga 1200
:lol:
...and also energy-consuming incandescent bulbs Image
Best regards
electroremy
Re: Control Rune Audio via TCP/IP commands
Postby janui » 24 Apr 2020, 08:18
Hi electroremy,
Very impressive kit, nice project. You can issue a whole load of control commands via html. Most of the commands supported by MPC are supported by RuneAudio (see here for the MPC manual: https://linux.die.net/man/1/mpc).
The format for RuneAudio is:
http://runeaudio.local/command?cmd=<MPC_command>
Examples:
http://runeaudio.local/command?cmd=play
http://runeaudio.local/command?cmd=next
http://runeaudio.local/command?cmd=stop
http://runeaudio.local/command?cmd=volume -10
http://runeaudio.local/command?cmd=volume +10
Postby electroremy » 25 Apr 2020, 19:30
Thank you very much !
MPC command are very pratical and they do not need a powerfull µC so it's perfect for Arduinos projects
Indeed, I try to control Rune Audio with a smart phone via the local web site and it's very efficient too.
Best regards
electroremy
