Installing Alsaequal
Postby hokamyiu » 30 Jan 2020, 16:32
hi there,
I'm trying to install Alsaequal on Rune Ver. 0.5 build janui-20180903-11 and followed the instruction from the below post -
tutorial-install-alsa-equal-t3178.html#p11556
I could only get as far as to step 3 -
pacman -S base-devel
always get these error messages
"error: failed retrieving file 'gcc-libs-8.2.1+20181127-1-armv7h.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error:
404 warning: failed to retrieve some files
error: failed retrieving file 'gawk-4.2.1-2-armv7h.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404."
for all 33 packages during the process.
what could have gone wrong ?
Keith
hokamyiu
Re: Installing Alsaequal
Postby hokamyiu » 01 Feb 2020, 06:27
From the forums of Arch Linux, learned that pacman -S would cause inconsistencies on glibc, and pacman will not function after the command.
Nonetheless I've built another RuneAudio image and retried. Now I am running into another issue with pacman -Syu (which updates glibc) -
Enter a selection (default=all):
:: Starting full system upgrade...
:: Replace ca-certificates-cacert with core/ca-certificates? [Y/n] y
:: Replace libsystemd with core/systemd-libs? [Y/n] y
:: Replace pkg-config with core/pkgconf? [Y/n] y
resolving dependencies...
looking for conflicting packages...
error: failed to prepare transaction (could not satisfy dependencies)
:: libdmx: installing xorgproto (2019.2-2) breaks dependency 'dmxproto'
:: libxxf86dga: installing xorgproto (2019.2-2) breaks dependency 'xf86dgaproto'
It says it failed to prepare transaction as it could not satisfy dependencies ? How to resolve these dependencies?
BTW mine is a Raspberry Pi3 (not an odroid where the tutorial was for), are the steps the same ?
Appreciate your help!
Keith
hokamyiu
Postby hokamyiu » 10 Feb 2020, 13:12
hi,
Would greatly appreciate any help on resolving the above issue!
Thanks!
Keith
hokamyiu
Postby gemmalyly » 18 Apr 2023, 07:49
This was a really thoroughly researched paper with a ton of evidence to back up its assertions. It was impressive to see such a detailed examination of the subject.
gemmalyly
Postby pebbleorange » 25 May 2023, 04:04
No one has been able to answer this yet ?
pebbleorange
