7" touchscreen
7" touchscreen
Postby lvant1 » 30 Dec 2019, 16:41
Hi all,
I installed today the image RuneAudio+R_e2-RPi2-3 on a raspberry pi 3. All works well except the 7" touchscreen. It's a white blank screen.
In debian you can install a driver (https://github.com/goodtft/LCD-show).
Is it possible to also use this screen in RuneAudio?
Kind regards, Jan
lvant1
Re: 7" touchscreen
Postby R101 » 30 Dec 2019, 17:39
It works for me, but remember this version is still under development.
Update the software and then activate the local browser in the menu. You should be able to use the settings under the icon to rotate the display and set the zoom level. There is no on-screen keyboard yet.
Re: 7" touchscreen
Postby lvant1 » 02 Jan 2020, 09:13
Thanks for the reply. After a update it still is a blanc screen. I wrote the question wrong, sorry. The HDMI output to a screen works just fine. Instead of using HDMI, I have installed a 3,5 inch LCD screen (https://nl.aliexpress.com/item/32906504 ... 4c4d4ZP6Dw).
To use this screen in debian I have to install a driver. Its probably the same here but how do I do this?
Regards, Jan
lvant1
Re: 7" touchscreen
Postby R101 » 02 Jan 2020, 11:54
If a search does not come up with anything, I suggest you start another thread with a relevant title.
