mount local files on extended partition
Postby Cully » 18 Jan 2017, 00:38
I have extended the partition to 32Gb . have created folder /home/music and copied music files/folders to /home/music.
How do I now add /home/music as a source or network mount so I can browse the folders.
Or ideally add /home/music as a bookmark on the library screen?
Cully
Re: mount local files on extended partition
Postby hondagx35 » 18 Jan 2017, 11:33
Postby avgddash » 13 Mar 2017, 21:14
Thanks Support!
I installed Rune on a Raspberry Pi 3 with a Digi+ SPDIF interface a few days ago.
I could not find out where to store music files on the local SD card, and didn't want
to permanently plug in a USB flash drive.
This answer should be in the FAQ, if not the WIKI!
Now I'm playing beautifully from the RP -> SPDIF -> Topping32ex amp.
Thanks,
avg
avgddash
Postby Suppertime » 07 Oct 2019, 21:54
Noob here, trying desperately to access music on the 2nd partition of my 128g sd card.
The advice is to mount the partition to /mnt/MPD/LocalStorage.
Is this possible without a computer running linux? If you only have a Windows PC, would it ever be possible to mount a partition in this way?
Suppertime
Postby cmh714 » 08 Oct 2019, 15:43
