SoloPiAmp
SoloPiAmp
Postby gEnEsis_AiX » 16 Oct 2014, 09:11
gEnEsis_AiX
Re: SoloPiAmp
Postby Aquarius » 16 Oct 2014, 14:57
Reply to some questions I hope not to be totally wrong:
- preamp needed ? Not strictly because for i²s dacs like the Hifiberry, you may use the volume control inside Rune. BUT. It's supposed to be something bad, according to audiophiles. You want volume control to take place in the analog world (i.e. after the DAC).
- To put a potmeter on the thing you need a Pre-amp different than volume control inside RuneAudio.
- With some code writing, and/or a script found on the net, you should be able to open/close a relay with the numerous GPIO on the Pi. so basically, you can use RunUI so switch off the Pi, then during the shutdown process, activate the relay to unpower the Amp board, pre amp, or whatever else you have in there, and then make sure that turning the Pi back ON with a switch will also close the relay to power up everything else. (an init script seems to be your best bet).
-- Aquarius
Aquarius
Re: SoloPiAmp
Postby matt » 16 Oct 2014, 19:30
I am intending on building the same thing and i too am concerned about my lack of electrical knowledge and have the same confidence re soldering.
I have just bought the "red" TPA 3116 board with built in volume control. I think this is the least liked of all the varients but I can swap it out later as they are so cheap, if so desired.
I am doing a very basic pi + power suppy in an aluminium enclosure as my first project.
There heaps of knowledge on here so just I am sure we will get there in the end. I
Please update your progress on here.
matt
Re: SoloPiAmp
Postby Fishstix » 16 Oct 2014, 20:12
Hey Guys,
I wouldn't be too scared of Soldering, it's pretty easy to pick up, and a great skill to have. Also the practice is *cheap.* :) When I first started, I just bought 1 dollar worth (read: a fistful) of cheap, through-hole resistors from radio shack, and a cheap prototyping board (with copper rings, so I could could practice heating wire and PCB traces at the same time.) I also picked up a small roll of de-soldering braid for a few bucks. Some people like solder suckers, but I find them overkill for the relatively small components I work with. For all of these along with a cheap soldering iron, you can spend as much time as you want soldering them to the board, then unsoldering, and then resoldering. Just takes a little bit of practice, some observation as to what you are doing, and a tiny bit of patience. To date: no cold shoulders (knock on wood) and no burnt components (knocking again.)
Lady Ada and Sparkfun both have good tutorials on basic soldering, which even being fairly familiar with, I learned new things from.
Lots of good info on these forums as to power supplies, pots, etc. Ask if you get stuck or worried; someone will be along to help you pretty quickly. You'll do just fine.
All the Best!
-Fishstix
Fishstix
Re: SoloPiAmp
Postby matt » 17 Oct 2014, 02:54
Cheers for that Fishstix.
Your username makes me wonder, are you a Kanye fan? ;)
matt
Re: SoloPiAmp
Postby gEnEsis_AiX » 17 Oct 2014, 10:10
gEnEsis_AiX
Re: SoloPiAmp
Postby skrodahl » 17 Oct 2014, 22:51
-skrodahl
skrodahl
Moderator
Re: SoloPiAmp
Postby gEnEsis_AiX » 18 Oct 2014, 19:59
gEnEsis_AiX
Re: SoloPiAmp
Postby skrodahl » 19 Oct 2014, 10:32
-skrodahl
skrodahl
Moderator
Re: SoloPiAmp
Postby gEnEsis_AiX » 19 Oct 2014, 14:29
Næmmen, hei fra det blide vestland :) (for those not familiar with norwegian - Hello from the happy west-part of norway)
I got everything lined up, just need a female socet for power inn, and shielded power cable / speaker cable - but i cant find any usefull on ebay - what do i search for (only found for 1000-2000 NOK)
When it comes to case, i need a case that is broad enough to be able to use the HDMI cable (PI is 56mm) and then i need an angled plug.
So it has to be:
( Pi lenghts (86mm) + amplifier (64mm) ) x ( PI width ( 56mm) + hdmi 270 degree angle ( 50mm ???) ) = 150 x 110 ish. should add some on both the lenght and width - so 180 x 120 ( then i can also have the tpa3116 board (the blue one)
Do i forget anything?
gEnEsis_AiX
Return to DIY and tweaks
