Problem installing ON/OFF SHIM (Pimoroni)
Postby klettervirus » 29 Mar 2019, 17:17
I tried to install a hardware switch (ON/OFF ShHIM from Pimoroni). It needs to run an install script:
curl https://get.pimoroni.com/onoffshim | bash
When I trie that, it does not install the script but tells me something else:
"Running as root, please log in as a regular user with sudo rights!"
I do not understand, does that mean that a nromal user using "su" can do more than root? What is it that I need to do to install the script?
Thanks in advance for the help, kindest regards, Stefan
klettervirus
Re: Problem installing ON/OFF SHIM (Pimoroni)
Postby janui » 01 Apr 2019, 17:03
Postby klettervirus » 01 Apr 2019, 19:24
Thanks so much, will try that!
klettervirus
Postby andre_chang » 05 Sep 2019, 15:32
This way can realize the shutdown state, click the button to start it?
andre_chang
Postby janui » 06 Sep 2019, 08:08
Users browsing this forum: Bing [Bot] and 8 guests
