New User
New User
Postby ubergoober » 10 Aug 2019, 04:32
I've just successfully loaded up Rune 0.5 on a Raspberry Pi 3 with integrated 802.11. Added my Firefly DAC and a fairly large USB stick and coupled it with the 7" touch screen and a case that holds it all together. I did all of this by braille but now I'm needing some further guidance.
I've read that MPD clients can stream, but I see no settings in the UI that govern the streaming port. Is this a function that Rune Audio now supports? I've seen I can turn on AP functionality. Does it only stream while in AP mode? My 12 year old kid isn't impressed that the phone in hand can remotely change the volume instead of putting the music into said phone. :-)
Further, do I have any options for using my exiting Sonos One speakers to play audio?
Thank you!
ubergoober
Re: New User
Postby janui » 10 Aug 2019, 11:11
Re: New User
Postby ubergoober » 10 Aug 2019, 19:03
Well, that's certainly not what I expected. When I added that output config to the /home directory, it completely replaced my UI managed configuration. I was left with no Samba shared library and no wifi connection. I really don't want to have to manage the configuration manually. Is there a way to layer that output in alongside the existing configuration like we see with conf.d subdirectories where the managed config is in the base .conf file and user configs get layered in from files in the subdirectory?
Thank you.
ubergoober
Re: New User
Postby janui » 12 Aug 2019, 09:34
Re: New User
Postby pebbleorange » 25 May 2023, 07:44
Well, I surely did not anticipate that. When I added that output configuration to my /home directory, it supplanted my UI-managed configuration entirely. I was left without a shared Samba library or wifi connection I would prefer not to manually administer the configuration.
pebbleorange
Users browsing this forum: Majestic-12 [Bot] and 3 guests
