Enable FIFO Output
Enable FIFO Output
Postby siam28 » 14 Oct 2014, 08:29
siam28
Re: Enable FIFO Output
Postby ACX » 14 Oct 2014, 14:15
Hi siam28,
the right file is /etc/mpd.conf, have you edited that one?
When you manually edit it you should only get a warning in the UI, telling you that manual modifications have been done, losing the possibility to use the configuration wizard. But manual modifications should stay after a reboot... what else did you do?
Postby siam28 » 25 Oct 2014, 05:15
siam28
Postby ACX » 25 Oct 2014, 10:57
Postby siam28 » 02 Nov 2014, 09:46
Hello ACX,
I found the issue. The reason the MPD service was failing was due to a permission issue.
I had to give the "mpd" user ownership of /tmp/mpd.fifo.
I was creating it as root via mkfifo.
siam28
