Delay / time lag when streaming video sound.
Postby chrichri » 18 Jan 2019, 11:04
I am using Ubuntu 18.04 with pulseaudio-dlna to stream video sound to an RPi 3B+ with RuneAudio and a Hifiberry DAC+ sound board.
Works fine so far, except a 1-2s sound delay.
I already found a similar post but this was related to Win10.
I have a gigabit network at home, so network speed should not be an issue. The time delay appears both on LAN and WLAN. My guess is this is a buffering issue when RuneAudio is used as a DLNA renderer.
Any ideas how to approach this issue?
Thanks in advance and best regards
Chris.
chrichri
Re: Delay / time lag when streaming video sound.
Postby eea123 » 18 Jan 2019, 11:37
This is a new playback arrangement to me, so maybe others will help. A quick Google search pulled up this discussion, https://askubuntu.com/questions/187086/ ... ant-device It sounds like the lag may be inherent on most devices, PI or otherwise.
Would it be acceptable audio quality-wise or possible hardware-wise to line level the monitor / TV's audio back to the stereo for playback? I'm using a pair of Niles CAT5 Video & Stereo Audio Transformers to feed the signal back to the stereo in my Den from my TV in the Living Room. I understand my setup is a 2-channel analogue solution only, but Niles also has similar HDMI and Coaxial digital solutions.
eea123
Postby chrichri » 18 Jan 2019, 13:23
chrichri
Postby eea123 » 19 Jan 2019, 11:20
Chris,
Just for clarity, the Niles Audio balums to CAT5 use a dedicated point to point cable run and are not switched thru a hub. Here's a link to the manual, . Page 3 shows their other passive balum offerings. They also have a powered series for longer runs, split feeds, ect.
Thanks,
Ed
eea123
