Rune freezing when no internet available.
Postby Jpetsch » 21 Nov 2018, 13:53
Hi all. Hoping for some help. I have used version 0.4 and 0.5 on 2 seperate raspberry pi's but the behaviour is the same.
I get freezing of the web ui and or remote app but only when connected to a network or router not connected to the internet.
Strange I know. I have tried static and dhcp.. no different. The ui locks up for around 2-3 minutes then will respond again for 30 seconds then freeze again. It's quite strange. Even happens with just the pi and a pc with a crossover cable. Any ideas?
Jpetsch
Re: Rune freezing when no internet available.
Postby Jpetsch » 24 Nov 2018, 01:15
Can anyone please just do a simple test to see if I'm alone.
All I ask is to set a static IP on rune use a crossover cable from a computer or laptop.
Open the ui and hit play. Then try to fast forward and rewind a few times and open settings or any of the menu options and see if it locks up?
I have tried this on 2 different rpi's with 2 different power supplies, with and without DAC's on the 0.4 and 0.5 builds.
Even tried 4 different brand routers in case something was being blocked. But when it did it with just a crossover I knew it was something locally on the pi.
Jpetsch
Postby janui » 24 Nov 2018, 09:47
Hi Jpetsch,
have you seen this post: runeaudio-0-4-beta-for-raspberry-pi2-3-t4434-460.html#p24971
I have not tested, but I don't think you are alone with this.
Postby Jpetsch » 25 Nov 2018, 10:05
Thanks Janui
So there is there any way to disable the particular features mentioned? I have already disabled cover art etc. And the problem still exists.
Jpetsch
Postby janui » 25 Nov 2018, 11:05
Postby Jpetsch » 25 Nov 2018, 11:23
This works perfectly. Thank you so much.
Jpetsch
Users browsing this forum: Majestic-12 [Bot] and 4 guests
