Want to ssh into pi running runeaudio. Need password!
Postby jj82 » 03 Apr 2015, 11:00
I would like to log into my raspberry pi running runeaudio via ssh but i can't seem to find details about the password. In setting (via the web interface) it tells me that the hostname is runeaudio but i still don't know the password. Anyone able to help? Cheers in advance.
jj82
Re: Want to ssh into pi running runeaudio. Need password!
Postby hondagx35 » 03 Apr 2015, 11:15
Hi jj82,
did you read the ?
Postby djlovemachine » 04 Mar 2016, 09:16
Frank, the docs dont give you an ssh login
djlovemachine
Postby hondagx35 » 04 Mar 2016, 09:20
Postby Pete » 23 Nov 2018, 21:16
I tried the Pacman command line but that didnt solve it. looks like ill have to figure out how to install the Edmiax drivers myself. thanks again.
Pete
Postby R101 » 24 Nov 2018, 12:38
Pete,
It would be helpful if you can say what is the problem you are trying to solve and what version of Rune you are using with which hardware. For instance, if you are using an Edimax wifi dongle with 0.5, there are a couple of files you need to add. Is that what you want to do?
