User Interface
User Interface
Postby diode84 » 29 Oct 2018, 15:09
Hello Everyone
Just been given a Pi 1, am totally new to Pi and loaded runeaudio rpi 0.3 beta. My question is does it have a GUI that comes up on the tv screen. If not do you do one that does.
diode84
diode84
Re: User Interface
Postby hondagx35 » 29 Oct 2018, 15:24
Hi diode84,
please read .
You also can try this version
runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532.html
Your Pi1 isn't the best version from a performance perspective.
Re: User Interface
Postby diode84 » 29 Oct 2018, 19:22
Thanks Frank, I know the P1 is not ideal but all I have until I sound the Pi out.
Also I did read what you advised and to me it was a bit ambiguous, it could be my brain but has it any internal user interface or must it always be played on the web interface.
diode84
Re: User Interface
Postby Cyborg_delta1 » 29 Oct 2018, 20:38
Your best bet with a Pi1 is to use the web interface from your phone or PC for performance reasons also the local interface was designed to be used with a touch screen so mouse support is limited unless you change some settings in a config file to get the mouse pointer to show up other wise you are navigating blind
Cyborg_delta1
Re: User Interface
Postby janui » 29 Oct 2018, 21:05
Re: User Interface
Postby diode84 » 29 Oct 2018, 21:53
Thanks everyone I will give up Runeaudio on my P1. I may get a later Pi at some time in the future.
I know a web interface works but am not keen on using two devices unless I am in another room.
I really want to make a poor mans SONY HAP-S1, with a screen, connected to the audio system and controlled by a remote controll. I
diode84
diode84
Re: User Interface
Postby nroeth » 19 Dec 2018, 13:58
nroeth
