USB storage looks empty, but the USB mount exists
Postby lognmk » 10 Oct 2018, 21:50
RuneOs: Experimental Beta 0.5 20180903
RuneUI: 0.5b (gearhead)
Hw-env: RaspberryPi 2 / 3
Hello members,
Just updated to 0.5b version. The installation was smooth and everything works perfectly.
I removed my external HDD and connected to my Windows Laptop to copy some music files to the HDD.
When putting the HDD back to Runeaudio, in the LIBRARY tab, the USB Storage was empty:
USB Storage (0)
no USB storage plugged
But in Sources, I can see the USB mount, I can see the HDD when connected with ssh and also, if I search in the library I can find all music tracks.
I have rebooted the device many times and mannually rebuild the library, without result.
Any help?
Many thanks for the excellent work
lognmk
Re: USB storage looks empty, but the USB mount exists
Postby janui » 11 Oct 2018, 08:40
Hi lognmk,
Could you look in the Debug UI, there is a line in the first section which looks like this:
Build version: janui-20180903-3
If the last number is not a 3 or higher you need to get the latest updates, for instructions see here: http://www.runeaudio.com/documentation/ ... rd-updates. It should fix your problem.
If the number is already a 3 please report back, I will need to look at it in more details.
Postby lognmk » 11 Oct 2018, 09:08
lognmk
Postby janui » 11 Oct 2018, 09:44
