How to edit a mpd.conf file
Postby doxyq3 » 15 Sep 2014, 17:42
How do I edit a mpd.conf file?
Bear with me I am new to Linux.
Thanks.
doxyq3
Re: How to edit a mpd.conf file
Postby skrodahl » 15 Sep 2014, 21:15
Hi doxyq3,
If you are considering editing the mpd.conf file in RuneAudio, I would recommend against it. The reason is that the settings from RuneAudio's web interface will stop working and/or you risk that you lose the changes on a reboot.
That said, It's cool that you want to learn Linux. Editing config files is an important part of your quest, and there are a lot of tools that will help you.
Basically, you need a text editor. There are many to choose from, one of the easiest to get started with is . It's modeled on the age old killer app from the operating system.
The default editor in all Linux systems is (VIsual editor). The learning curve is quite steep, but it's a fast, efficient and powerful editor once you get the hang of it.
The vi editor will make you lose interest immediately, especially if all you want to do is a quick change in a file. I will recommend that you look into vi if you're serious about learning Linux. Or Emacs. (Yes, I just opened the can of worms that is .) With that can opened, you can go on to see that there is a .
In case you got confused along the way, for a quick and relatively simple editing experience: Go with . (Click the link for a tutorial.)
-skrodahl
skrodahl
Moderator
Postby Aquarius » 16 Sep 2014, 11:18
lol :)
Nano fits most purposes for sanity-concsious people...
-- Aquarius
Aquarius
Postby Dukobpa3 » 16 Sep 2014, 11:32
Lol. Also you cat try to do it with 'sed' command ))))
Dukobpa3
