Spotify on Rpi3
Spotify on Rpi3
Postby nickvas19 » 24 Dec 2017, 11:20
hello
I have premium account in Spotify. Also i put correct the account to my rpi3. Well i do a playlist and after i go to library. When i click on spotify it saws me a circle like something is loading but nothing happends.
any ideas?!
nickvas19
Re: Spotify on Rpi3
Postby janui » 24 Dec 2017, 11:50
Hi nickvas19,
There are some problems with Spotify, search the forum for details.
What you should get is a list of your own playlists, the playlists which you follow will not be shown. It is very slow and takes quite a while to load the information. But it works.
P.S. On 20-12-2017 Spotify announced that they have given permission to the Lunix foundation to pre-install the Spotify software in the standard Linux distribution :D So, there is a good chance that the current Spotify problems will soon be fixed and the possibility of more features.
Also thanks to Spotify for the Christmas present for all Linux audio enthusiasts.
Re: Spotify on Rpi3
Postby nickvas19 » 24 Dec 2017, 11:55
I create my own playlist...but the circle still is here.
Well if it possible someone to tell me exactly that to do ...cause i didn't understand much .
thanx
nickvas19
Re: Spotify on Rpi3
Postby janui » 24 Dec 2017, 12:02
Hi nickvas19,
Are you loged into Spotify on another device? You can only have one active session (per account), Rune is not capable of taking over an active session. The other way around, the Spotify App can take over a session from Rune.
Re: Spotify on Rpi3
Postby nickvas19 » 24 Dec 2017, 12:22
thanx for your quick response.
wooow.my bad....you mean i must log off all my devices from spotify in order to play on rpi3?
nickvas19
Re: Spotify on Rpi3
Postby janui » 24 Dec 2017, 12:24
Hello nickvas19,
I have just tried Spotify my own Rune installation. I have exactly the same problem. I don’t know what has changed. Could you supply the first 20 lines of your debug information so that we know exactly which version of the software you are using. I will do some testing during the next couple of days.
Re: Spotify on Rpi3
Postby nickvas19 » 24 Dec 2017, 12:42
thanx doing that for me.
my version is release version: 0.4b (build: 20170229)
nickvas19
Re: Spotify on Rpi3
Postby nickvas19 » 24 Dec 2017, 12:43
if you want something else about my version tell me know.
i will be waiting for your test results.
a big thanx.
nickvas19
Re: Spotify on Rpi3
Postby hondagx35 » 24 Dec 2017, 12:43
Hi all,
I did a quick test with a fresh installation (from ) and it works without issues.
I do not use Spotify at all, so I can't tell you something about reliability.
Is your installation modified (kernel-, mpd- or other updates)?
Do you use special characters with your password?
Re: Spotify on Rpi3
Postby nickvas19 » 24 Dec 2017, 13:06
it's clear.... i don't change anything on mpd,kernel etc.
my number account have only numbers.
nickvas19
