RuneAudio for Noobs
RuneAudio for Noobs
Postby Boilers » 30 Jul 2017, 03:30
Early warning: I am a complete beginner in every aspect to linux and operating my RPi 3b. I have had a nightmare of a time trying to get RuneAudio to cooperate with me. With that being said, these are the difficulties I've run into:
1) When trying to access my RPi through putty, I am given an error that the host does not exist. I am listing runeaudio as the host.
2) RuneAudio really does not want to connect so my Wifi. When using Raspbian I have no problem whatsoever connecting, but RuneAudio doesn't seem to respond when I enter my login info. I have tried switching my IP to static, checking that all required fields are 0.0.0.0, then switching back to DHCP, and have had no luck.
3) When attempting to connect play spotify, it acts as though it is permanently buffering/loading. I suspect this problem will be solved once I can connect to wifi, but I am not sure if it will so I'll mention it anyways.
I apologize in advance, I have essentially no coding/developing background so linux is terrifying to me (They only teach us to use glorified calculators in aerospace engineering (matlab)) Any help would be greatly appreciated
Boilers
Re: RuneAudio for Noobs
Postby hondagx35 » 30 Jul 2017, 13:35
Hi Boilers,
we need more information:
- while trying to setup your wifi connection you are connected via ethernet?
- the version you are using is the one from the download page (v0.3-beta (23/03/2016))?
- on what channel is your access point transmitting?
- do you try to use the built-in wifi?
If you like you can try the latest test image from .
Postby Boilers » 30 Jul 2017, 16:28
Boilers
Postby hondagx35 » 31 Jul 2017, 09:42
Postby Boilers » 31 Jul 2017, 11:18
Here's what it looks like. All other features seem fine, it's just the spotify button.
Boilers
Postby Boilers » 05 Aug 2017, 21:35
Any suggestions on this? I know I'm not the first to have this issue
Boilers
Postby hondagx35 » 05 Aug 2017, 22:09
Postby Boilers » 06 Aug 2017, 17:44
Frank,
It turns out I needed to switch my playback source from spotify to MPD. I could then toggle the spotify option and input my login and everything worked fine except for some weird bug where I couldn't adjust the volume. I will note that after spotify was up and running, I went and checked the spotify toggle in settings, and it was once again greyed out. I'm not sure if this is intentional or not, but just a heads up. Thank you for the great support!
Boilers
