is this a problem that should be addressed?
Postby tsawyer » 16 Jul 2017, 22:58
I just downloaded Raspberry Pi 3(model B) version today and ran the standard update. the problem I ran into was when I attempted to install java. I was unable to reach the arch linux mirror to run 'pacman -S jre8-openjdk-headless'. I had to resync pacman by using 'pacman -Syu'. I did not have that issue under a different build (Raspberry Pi (model A/A+/B/B+)).
is this a problem for other things or did I just open up a can of worms on this build? ultimately I want to have the box host both rune and subsonic so I'm documenting the process and issues
tsawyer
Re: is this a problem that should be addressed?
Postby hondagx35 » 17 Jul 2017, 06:35
Postby tsawyer » 17 Jul 2017, 18:36
ok, that's fine. I would like to know how to install java as I posted. it seems like I can not point to a correct repository
tsawyer
Postby hondagx35 » 17 Jul 2017, 18:38
Postby rern » 18 Jul 2017, 16:28
