DAB integration?
Re: DAB integration?
Postby jon3 » 12 Dec 2016, 13:54
I hope that we can expect something about this whole thing and could be in the next version we expect this all together is available.
jon3
Postby bo.vestergaard » 13 Dec 2016, 13:42
How are you guys getting on with this? I am very interested in doing the same. Both DAB and FM radio on my Runeaudio PI would be fantastic. Keep us posted :)
bo.vestergaard
Postby daviestar » 13 Dec 2016, 14:06
The situation may be different now, but the roadblock I hit was while we could get a 'hello world' from FM transmissions through rtl_fm, there was no compatible CLI available for DAB/DAB+ tuning.
daviestar
Postby hangman » 28 Jan 2017, 10:42
I have good news!
Command line DAB radio player is coming to the Rpi + RTL2832U/R820T. A guy named Albrecht Lohofener has started a fork of Jan van Katwijk's dab-rpi (sdr-j). He is programming on no less than FOUR user interfaces (versions) for the player.
From the README:
dab-rpi
This repository contains the implementation of a simple DAB/DAB+ receiver. It is derived from the sdr-j-dab software, optimized for embedded systems like Raspberry Pi 2 and Raspberry Pi 3 but it runs on regular PC's as well.
The receiver supports terrestrial DAB and DAB+ reception with as input the samplestream from either an AIRSPY, a SDRplay, a dabstick (rtl_sdr), a rtl_tcp server or a (prerecorded) file. It will give sound output through the selected soundcard or - if configured - through a TCP connection.
There are now FOUR versions of the dab-rpi software, the set is extended with a "command line only" version.
GUI_1 is a version with a GUI using regular QT widgets, it can be build with Qt4 and Qt5;
GUI_2 is a "command line" version. i.e. no widgets at all, no flexibility, just pass the channel, the program next to Band, Mode and Device (of course there are defaults).
GUI_3 is a touch and high DPI display optimized GUI based in QT QML. It can be build using Qt5.7 and higher.
GUI_4 is a version without a GUI, the program is controlled remotely using a TCP connection. A simple remote controller is included in the sources; The dab-rpi version - the simple remote controller as well - can be build using Qt4 and Qt5;
https://github.com/AlbrechtL/dab-rpi
Have a good look at the README.GUI_[1-4].md files.
hangman
Postby hangman » 05 Feb 2017, 19:29
dab-rpi update:
Albrecht Lohofener's dab-rpi has now changed it's name to welle.io , and is available at https://github.com/AlbrechtL/welle.io .
Jan van Katwijk's dab-rpi seems to continue at a steady pace, and it's located at https://github.com/JvanKatwijk/dab-rpi
It seems like these projects are being developed in parallell with a cooperation between them.
hangman
Postby jon3 » 06 Feb 2017, 10:56
It might even for runeaudio what to edit in order to be able to listen to DAB/DAB and FM radio stations, of course, I hope that there will be something in the new update, so you can only use it in the car, I could then just with a remote control and would be taken care of. ;) :D 8-)
jon3
Postby tegger » 10 Mar 2017, 13:50
Jvan Katwijk started an own cmdline Version:
tegger
Postby andib » 17 Mar 2017, 21:06
i'm new to runeaudio. But whe i hear DAB in runeaudio .... amazing!! I hope somebody could integrate this in some manner .....
Thank you for your work!
andib
Postby andib » 31 Mar 2017, 15:30
Please ... please please bring DAB to the next 0.4 Beta. This is amazing!! Please Keep us posted.
Thank you for the great project!
andib
Users browsing this forum: No registered users and 25 guests
