Control (play, pause, volume) over TCP
Postby fohnbit » 23 Jan 2016, 10:29
is there a APi to control RuneAudio over TCP oder UDP?
Thank you!
fohnbit
Re: Control (play, pause, volume) over TCP
Postby hondagx35 » 23 Jan 2016, 11:26
Postby fohnbit » 23 Jan 2016, 12:11
perfekt .. will try.
Thank you!
fohnbit
Postby Dombo71 » 27 Feb 2016, 20:49
how do i come/see this option..
To see the api of the commands..
Dombo71
Postby Dombo71 » 20 Mar 2016, 19:17
Please some one tel me how i can play with Rune from tcp...
Dombo71
Postby Dombo71 » 20 May 2016, 23:51
In the new version perhaps a better option to control Rune with a api?
Or http controls?
Like openremote or something..
Dombo71
Postby dejaybaze » 02 Feb 2017, 17:59
I'll just messed around and found some TCP commands.
TCP port: 6600
Commands i'll sendt was:
play\n
stop\n
next\n
Works like a charm....
dejaybaze
Postby Stephane » 08 Feb 2017, 10:40
On port 6600 you are controling MPD, not Rune. [WINKING FACE]
Stephane
Postby codefusionllc » 06 Dec 2018, 06:59
So, What about getting Playlist information over TCP?
Is that only available via the HTTP calls then?
i.e. http://192.168.1.13/command/?cmd=listplaylists
When I try and send 'listplaylists\n' through the TCP API, it just shrugs and says 'OK MPD 0.19.0\n'.
codefusionllc
Postby hondagx35 » 07 Dec 2018, 16:32
