Cannot skip in large mp3
Postby Gabor » 19 Jan 2017, 02:41
In a 320kbs large mp3 (longer than one hour) when I skip to say 40 minutes the file restarts playing from the beginning after a few seconds. Increasing the buffer to 16384 did not help. I can skip in the same mp3 just fine in Moode Player so the cause must be a local setting in Rune. Any help would be much appreciated, search hasn't returned an answer.
(Rpi3 with Pi-DAC+ and latest Rune downloaded today on class 10 card, ethernet connection to WD NAS)
Gabor
Re: Cannot skip in large mp3
Postby Gabor » 20 Jan 2017, 00:56
Exact same behaviour (several seconds silence after skipping and then plays from start) when playing the same file from another gigabit NAS drive (WD MyCloud). Playing the file from a USB stick in the RPi is perfect, playback continues within a second after skipping anywhere in the file.
Is the 100 mbps ethernet of the RPi3 too slow for a 320 kbps mp3? Probably not. It must be a suboptimal setting in network transfer in Rune because Moode Audio skips perfectly, as when playing from the USB stick in Rune.
Has anyone found the same? Is there a fix?
Gabor
Postby Gabor » 20 Jan 2017, 01:27
Little correction: Moode Audio is silent for a few seconds after skipping but then continues to play.
Gabor
Users browsing this forum: No registered users and 20 guests
