Hifiberry DAC+ not detected after kernel update (Rpi3)
Postby truckinve » 19 Nov 2016, 19:29
Hello everyone , first post here!,
Some days ago, I decided to get a Spotify premium trial and check it with Runeaudio. I got some pops and swapping in the channels while playing only in the Spotify option.
So I updated the kernel via SSH as described here and gitpull also. But now I can`t find my DAC+ and even I tried these settings:
- Un-comment Hifiberry DAC+ in config.txt like the first time I installed Rune. Then sync ,then reboot.
- Checking settings for I2S kernel devices (no list displayed).
- MPD audio output says "Nothing Selected"
- Alsa only detects onboard audio and hdmi. If I disable in config.txt, it doesn't detect any card.
I tried every possible option described on some posts.
This is the debug info http://pastebin.com/pjJGdkXR
And a snapshot of the settings. Is that ARCH kernel the correct one :lol: :lol: ?
Thank you!
truckinve
Re: Hifiberry DAC+ not detected after kernel update (Rpi3)
Postby surfninja » 19 Nov 2016, 21:22
Truckin,
Here is what my MPD config looks like. I'm running Linux runeaudio 4.1.20-1 kernel. I don't think I changed this. This is on a Rpi2. Not sure if it matters. I did ssh into my RP and update the config file to:
# Uncomment one of these lines to enable an audio interface
#dtoverlay=hifiberry-dac
dtoverlay=hifiberry-dacplus
#dtoverlay=hifiberry-digi
#dtoverlay=hifiberry-amp
#dtoverlay=iqaudio-dac
#dtoverlay=iqaudio-dacplus
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby truckinve » 19 Nov 2016, 22:00
truckinve
Postby surfninja » 19 Nov 2016, 23:26
here is what I have. Also, my debug says:
###### System info ######
Linux version 4.4.27-1-ARCH (builduser@leming) (gcc version 6.2.1 20160830 (GCC) ) #1 SMP Sun Oct 23 17:26:59 MDT 2016
surfninja
Postby hondagx35 » 20 Nov 2016, 00:36
Postby surfninja » 20 Nov 2016, 01:07
surfninja
Postby truckinve » 20 Nov 2016, 17:12
Hi again
Aplay detected the Dac, thank you very much guys! . Will check the output on Spotify and give a response later.
Thank you!
truckinve
Postby kolia » 23 Feb 2017, 11:45
I followed guidelines posted here. I'm currently setting up a Digi + Pro. aplay -l now displays the correct sound interface. However Rune Audio interface menu still shows HifiBerry (I2s)
Shall I consider that everything is fine?
FWIW: I had to remove raspberrypi-bootloader from this command pacman -Sy --force raspberrypi-firmware raspberrypi-bootloader linux-raspberrypi to get it working
Thank you
kolia
