[SOLVED] Hifiberry DAC+ not listed in MPD audio output menu
Postby ABBDVD » 06 Jan 2015, 13:48
ABBDVD
Re: Hifiberry DAC+ not listed in the MPD audio output dropdo
Postby hondagx35 » 06 Jan 2015, 15:20
Hi Chris,
did you select / enable the i2s driver (HifiBerry DAC+) on the settings page?
Postby ABBDVD » 06 Jan 2015, 16:30
now I did. That was my problem. Thanks & solved.
(I do wonder a little that this isn't somewhere obvious in the documentation or in case it is, that my read/search skills are so bad. But I should have checked the settings in the first place, obviously.)
ABBDVD
Postby hondagx35 » 06 Jan 2015, 17:02
Re: [SOLVED] Hifiberry DAC+ not listed in MPD audio output m
Postby Remmy » 03 Jul 2016, 18:48
Hello, I have the same problem of my Hifiberry not being listed in the Audio Output Interface dropdown menu
I have tried to apply the described solution. Unfortunately this is not possible for me as the "I²S kernel modules" item gives me no choice and says "Enable I²S output by selecting one of the available sets of modules (in this version you have to edit /boot/config.txt), specific for each hardware. Once set, the output interface will appear in the MPD configuration select menu, and modules will also auto-load from the next reboot. "
I don't know how to edit config.txt : how to do that and what to write.
This is very annoying, as I can't use my hifiberry.
My version is : RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img
Can someone help me please ?
Remmy
Postby ambreswe » 18 Nov 2016, 22:24
I've the same problem, Hifiberry DAC is not in the list at all.
Also noticed that Runeaudio seems to think this is a Rpi2 ... it's not, it's a Rpi3
"HW platform
RaspberryPi2 (08)"
I thought I found the solution, edited /boot/config.txt to enable the Hifiberry entries, rebooted and... nothing :(
ambreswe
Postby hondagx35 » 18 Nov 2016, 23:26
Postby ambreswe » 18 Nov 2016, 23:35
ambreswe
Postby hondagx35 » 19 Nov 2016, 10:36
Hi ambreswe,
To get the best possible support, please specify your hardware and RuneAudio version. is also suggested.
Users browsing this forum: Bing [Bot] and 25 guests
