[SOLVED] how can i really disable auto update library
Postby nopphong » 17 Jan 2015, 12:43
hello
I try to use runeaudio as music server and it work very well.Thank for a wonderful program.
My problem is i connect 750G usb hdd with a lot of files in it.And it take a lot of times to update library.If it update only one time when i connect i think it ok i can wait.But it rescan every time i shutdown or restart my Rpi .
I already disable auto update library in MPD menu but it keep scanning.I try to disable ffmpeg decode and hope for faster scan but it still slow.
can you help me disable auto scan library ?
thank you very much
nopphong
Re: how can i really disable auto update library
Postby MeiT » 19 Jan 2015, 14:16
try to disable "Automount USB".
MeiT
MeiT
Postby nopphong » 20 Jan 2015, 03:32
nopphong
Postby hondagx35 » 20 Jan 2015, 18:25
Postby ACX » 21 Jan 2015, 01:47
Postby nopphong » 21 Jan 2015, 20:16
Thank you hondagx35 and ACX
With hondagx35 reply it work perfectly thank you very much.
But when I try to edit as ACX reply it still rescan hdd every tome i boot Then I edit it back.
Now it not rescan every time i boot and when i want to rescan i just go to source and press rebuild MPD library button.It perfect !!
nopphong
Re: [SOLVED] how can i really disable auto update library
Postby johnberg » 06 Nov 2016, 14:21
@Hondagx35
I try to do this with Putty, but I am oh so green with Linux.
Please can you give me one step by step guide to make this succesfull. :oops:
I logged in via ssh with putty: root password rune
Then make code select all with this:
nano /srv/http/command/usbmount
and pasted it in Putty by one click on the right mouse button
Then I did enter and see this: (attachment)
After I really don't what to do anymore abacadabra for me. :( :(
I have to change lin 62 but how do I come there?
I think it is very simple and googled a lot but no succes
I would very appreciate to give one step by step guide to do this maybe very simply handling.
Yes also I have an issue that Rune js every time updating when started up
johnberg
Postby hondagx35 » 06 Nov 2016, 23:23
