Raspberry Pi 3 and Mytek stereo-192
Postby sng » 26 Sep 2016, 04:23
Hi!
I installed Runeaudio on my RPi3 and was very delighted to have it working in my setup. However, when I connect the Pi to USB Audio Class2 on the Mytek, it reports 'no sync'.
I understand Linux is Class 2 compliant so is there something missing in my setup (driver perhaps?).
Any help will be much appreciated.
Thanks.
sng
Re: Raspberry Pi 3 and Mytek stereo-192
Postby hondagx35 » 26 Sep 2016, 11:07
Hi sng,
your DAC is selected on the MPD setings page?
To get the best possible support, please specify your hardware and RuneAudio version. is also suggested.
Postby sng » 27 Sep 2016, 01:15
Hello Frank,
Thanks for taking the time to respond.
The Mytek DAC does not show up in MPD when connected to the USB Class 2 port on the DAC. It does however, appear when I connect to the standard low speed USB port. The message on the Mytek says 'no lock'.
The version of Runeaudio I installed is "release version: 0.4 (build: beta-20160313)". It is installed on a standard Raspberry Pi 3. The DAC is a Mytek Stereo 192 DSD.
The debug info is in "http://pastebin.com/nSvumecM".
Thanks again.
Stephen
sng
Postby popov » 27 Sep 2016, 06:11
Hi Stéphan
Have a look here https://github.com/lintweaker/mytekusb2
You have a specific driver for usb2.
I don't find informations about alsa version. This is different between 0.3 and 0.4.
If not working in 0.4 you may have to downsize in 0.3
In mytek site i just see information about last macOS not supported.... So may have issues with last Linux kernel and alsa
Regards
Envoyé de mon iPhone en utilisant Tapatalk
popov
Postby sng » 27 Sep 2016, 14:38
Hello Popov,
Thanks for the link. I had a quick study of it. I will attempt to compile the driver (hopefully the version issues will not be a problem) and have a go installing it. I will let you know if things go well.
Stephen
sng
Postby dahumph » 10 Nov 2016, 18:08
Hi Stephen, I'm trying to do the same thing, compiling the ALSA driver for Mytek 192. Have you had luck so far? seems to be a little complicated to get it working...
dahumph
